Tilt issue with K975 Slider
dlwheel
Need some help.
I was tilting the blade on my K975 Slider and didn't realize the guard was still open.
The lip of the guard got pinched under the sliding rail and the tilting stopped.
I was able to work the hinged door loose but the saw will not respond to either tilting or raising the blade.
I pressed the reset plunger buttons on the back of the saw, but it will still not reset and allow the blade to return to 90 degrees.
Has anybody else encountered this issue.
Thanks,
David Wheeler
david@wheeler7.com
Not sure about the Felder but, do you have a panel to open up and check breaker status.  You may have tripped a breaker.
Steve
