- Oct 16, 2015
Richard/RMW said:I'm down to my last couple of disks and the one on the machine is ready to be replaced. They use a particularly nasty PSA that necessitates scraping off the disk surface and scrubbing it with lacquer thinner, it's enough of a PITA that I'll run a disk well beyond the point it should be replaced.
RMW
There's a little body shop trick that I learned back in the early 90's to mitigate that problem.
Of course, you have to go through the PITA to get the platen clean first, but hopefully it will be the last time.
You simply stick the new abrasive disc to your shirt, pull it off, and re-stick it (in a different place) then apply it to your machine's platen. The fibers and dust from your shirt will interfere with the "over-bonding" that most PSA discs experience. It won't make it so bad that it won't stick properly, but it will come off much easier the next time. If your shirt is sweaty, stick the disc to a cotton rag, stretched out on the bench top. Sweat is too much.
I do this with the 8" geared orbital sanders that I use for leveling solid surface seems. Ingersol-Rand 328b. The bigger problem with them is that the platen is not metal, therefore harder to clean. It's an aluminum backer with a dense foam padding and some kind of plastic skin? PVC maybe? so cleaning it with solvent takes a lot of care, which is why I avoid it like the plague. The shirt fibers do the trick.
[member=44099]Cheese[/member] do you have a part number for that 3M disc that fits the RAS?
