GaryLaroff
- Sep 23, 2008
I've cut plastics successfully with scroll saws on a smaller scale that might lead to the right answer. The blades Tom Bellemare showed have large gullets between the teeth on the suggested blade. With scroll sawing I found that the blade with the longest distance between teeth seemed to cause the least friction, heating the plastic the least and giving the best results. Regardless of number or coarseness of teeth, the blades with the least "chip clearance" between teeth caused the most mess.
Touch up with sandpaper on a hand sanding block worked best for me.
I second the advice of staying away from the bandsaw. I have a powerful shopvac dedicated to the bandsaw, did some successful cutting of plastic but had a horrendous cleanup job afterwards.
Gary
Gary
