Titan 2 sandpaper
dwillis
Yacolt, WA
I probably missed the FoG discussion, but I wanted to check and see if Festool still sells Titan 2 5 inch sandpaper for the ETS 150/5 EQ? If it's not available what is the recommended replacement? My primary use is finishing hard and softwoods using mainly 220 grit.
A little google search turns up plenty of Titan 2.
But Titan is not really meant for wood, but of course you can use it without problem. Titan is meant for the automotive industry, and has a flexible latex backing to better fit the contours of cars.
On wood, you'd be much better of with a pad and paper that's not flexible at all but very straight, that's why lots of users use the hard pad for their sanders on wood.
The perfect all-round paper for wood and almost every other surface is Granat.
Titan has been discontinued in the U.S.
If you find some , it should be discounted, because it's dead stock.
