Nippychippy said:Yep correct it has a grooving attachment it's amazing
ScotF said:I cannot find an 85, but I see that there is a HK132 with planer, groover and sawing -- that looks pretty slick.
https://www.festool.com/Products/Pages/Product-Competence.aspx?foc=ol_zimmerei_handkreissaegen_9770
Phil Beckley said:ScotF said:I cannot find an 85, but I see that there is a HK132 with planer, groover and sawing -- that looks pretty slick.
Hi
The 132 is from the Protool range and is a beast of a machine. Sadly not available in the UK but is in Europe
Rg
Phil
Tot said:Fix, mafell has too 25mm blades.
So:
1.) 7.0kg + 1.26kg with 8.8kg mafell. Fe wins.
2.) 420mm cross guide rail + custom length with 370mm mafell. Fe wins.
3.) More stock blades by Fe.
4.) 85-62-47mm cut (0-45-60 degrees), with rail looks like 80-56-38.5mm. Mafell has 88mm w/out guide rail, 82mm with. Same.
5.) Much better accessories by mafell with $600 groove unit by Fe.
6.) Sys-compatibility by Fe (!!!), has bag case for guide rail.
7.) HK 85 is cheaper even in Germany.
8.) Maybe mafell engine are better then Fe, will see. Btw no fast stop at kss 80ec (x3 more times for full stop, but more durable and less noisy).
RL said:Just announced: an EC 125 to go alongside the EC150, but oddly it has a 3mm stroke instead of the ETS 125's 2mm stroke.
