paulhtremblay
- Jun 4, 2014
I wanted to build a torsion assembly table with somewhat basic tools. Many of the plans on the internet require that you have a planer, a nail gun and a table saw. Could I construct the same with a Festool track saw, the parallel guides, an MFT3 table, and little else?
Many torsion box plans call for planing 2 x 4's to exact thickness and using these to create a level platform. Not having a planer, I ripped 8 pieces of MDF 100 mm thick. I would double up on each ripped piece to create the equivalent of a 2 x 4. However, when I straddled these pieces across 2 saw horses, I realized I had underestimated the weakness of MDF. Each piece sagged too much.
Instead, I placed the pieces on the floor and shimmed them to get a flat surface.
I stabilized the grid by screwing in two pieces of at the ends, seen in later picts.
(If I were to make another, I would use 4 pieces of MDF 200 mm wide; tall beams provide much more stiffness than wide ones.)
Next I cut the strips with the parallel guides. I measured the strips with a caliper and noted they differed by only about 2/10 of 1 millimeter.
Next I cut the blocks using the MFT3 table and the stop flag. Finally, I cut my two skins a bit oversize.
I used a glue gun to assemble most of the grid. I started using regular yellow glue, but feared some of it might lead on the other side of the web and compromise the glue up for the second skin. I'm glad I followed my reservations: in fact, when gluing the second skin, I saw some glue had gotten on the the other side of the web.
One problem I had was keeping the inner web square. Even though I used cross pieces, the flexibility of the MDF caused the end pieces to bow. If I were to build another, I would set blocks in the bottom skin to make a perfect square and build my web around that. Since I wanted the table perfectly flat, not not necessarily square, I decided to accept the bowing at both ends, though it did leave less overlap for the skins than I wanted and made the glue up a bit trickier.
Since I had built my frame on the floor, I could not use clamps to hold the skins in place. I did not have a nail gun, either. I could not have screwed in enough screws in time. I debated if I should buy bags of sand to place on top. On another forum, I was told I would need at least 5,000 pounds of weight to get enough pressure. Other posters questioned this. I did a small experiment by placing a flat piece of mdf on to the edges of two other pieces, in order to mimic my glue up job. I put only 3 books on top. The next day I could not break the glue bond.
Based on my experiment, I decided to use boxes of books. Quite a lot of glue dribbled on to the sides. Were this a finished project, the glue would have marred the perfect face of the MDF and made finishing very difficult.
The top came out perfectly flat.
