Trick for sanding curves with the RTS400
poto
I had to sand some concave corners on a table I was making, and I was having trouble getting a smooth curve where the leg met the table bottom. Using the RTS400, I kept forming a ridge in the leg where the sandpaper hit it. Then I came up with the notion to put the sandpaper only partially on the pad of the sander. I tried two configurations: the first one had the sandpaper hanging over the pad on two sides, the other had the sandpaper hanging over only at the front. I lined up as many holes in the sandpaper with the holes in the sanding pad as I could. It worked great! (Be careful not to put the sander flat on the surface, or you'll wear your h&l pad away.)
Here are some pictures of the two configurations:
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
The stiffness of the sandpaper gives a nice smooth curve to the sanding. It's not particularly aggressive, so you don't have to worry about gouging.
If you have an RS2E........you can use that paper and not worry about exposing the h&l pad.  Or you could stick another sheet of RS sized abrasive on the pad.
That's a great idea, Tim. For my purposes it wasn't difficult to keep the pad off the surface - I just angled the sander up a bit.  But for safety's sake, putting another piece of sandpaper on would solve the problem, particularly if you're just hanging the paper off the front of the sanding pad.
