Triton TRA-001 Router with Incra Router Plate Mod
jbasen
The Triton TRA-001 router with the Incra router table plate is a great combination for woodworking. It is an economical solution because the router lift is built into the Triton router. However, one issue I found is that when you took the height winder and put it through the hole in the router plate it was difficult to get it to engage with the router to adjust the router height because there isn't anything to guide it into place.
I just uploaded a 3D printed part to solve this issue to thingiverse. You can check it out and download the stl file here:
http://www.thingiverse.com/thing:1371576
I have this exact configuration, thanks for coming up with the solution. Not a big problem but it does become annoying.
zxcv said:
I'd like to have one of these, but where can I get it printed?
I did a quick google search for 3d printing service and a pile came up. You may be able to find one that is local to you.  I even found that some UPS stores are offering 3D printing services. Hope this helps
