Dave Ronyak
- Jan 23, 2007
What amount, if any wobble and end play of the arbor of the TS 55 is considered normal? Today while removing the blade for cleaning, I noticed that the arbor of my saw has both some wobble (I can tilt the arbor flange slightly and rock it slightly side to side) and some end play (I can pull it out relative to the motor housing and push it in relative to the motor housing). I strongly suspect this is not as it should be. Cut quality is not bad with a sharp, clean 48 tooth ATB blade from Festool, but there is some cross hatching even though the saw is properly adjusted including toe-in at the front of the blade per Rick Christopherson's manual. I am finding that I need to joint the sawn edges if I want a truly clean glue line.
The only other Thread/Post I could find regarding a similar issue is this one.
http://festoolownersgroup.com/festool-how-to/ts-55-end-play/
My suspicion is that my TS 55 has a worn bearing. Has anyone any other thoughts or suggestions other than sending it in to Festool for repair?
My saw has seen a decent amount of use as an amateur, but not enough to yet need replacement or resharpening of the original 48 T blade that came with it which seems to cut nearly as well as a new blade of the same Festool Item number.
Edit -- Sorry, Moderators! I just realized I should have posted this in the "Tool Problems" section of the forum. This message should be move to there.
Dave R.
Dave R.
