Tomfoolery
- Apr 20, 2012
Well - I took the plunge (so to speak) and started my Festool ownership with a TS 55 EQ + CT 36 e
My question is how do I adjust the saw so a bevel cut is in-line with a straight cut?
When i clamp my guide to a workpiece and have the saw set to 0 degrees - make a cut and then set the saw to 45 degrees and make a plunge cut shorter than the previous cut the top edge of the workpiece is not lined up.
The bevel cut seems to have the top edge 1-3mm closer to the saw. It is visibly noticeable.
Any ideas?
Thank you all in advance!
-Tom
Any ideas?
-Tom
