TS 55 Full Depth
Mario Turcot
I have been using the TS 55 for 1.5 year. I never cut material thicker then 3/4" (18mm). Today I had to cut ~2" (49mm). I setup the track guide and set the saw depth all the way down. I then manually engage the plunge to see if it was enough. The specs says 2" 1/8 but you never know. I realized that the blade was only going down 1"  [eek]
I couldn't find what was blocking the plunge until I notice the splinterguard was the issue.
It was not cut through and the blade was bumping on it.
[attachimg=2]
If it happen to you just run the saw at full depth free air and the splinterguard will not confused you like it did to me  [embarassed]
P.S. I need to clean my blade  [wink]
