Kodi Crescent
- Aug 6, 2010
I've been ripping some 5/4 Poplar with a TS55 using the stock blade (yes, I know, there is a rip blade). I cranked the speed control up to 6 and was cutting away. The motor was "screaming" although this may be normal at this speed. I usually keep the speed at 4.
After cutting for about 20 minutes, I noticed this very odd phenomenon that I hadn't experienced before. The saw is chugging along, cutting fine, and then it bogs down and nearly stops. The circuit breaker did not trip. I stop the saw, and then go to resume the cut, and the saw is spinning at a low power. The blade has some speed, but no torque. It does this for a few minutes, and then it regains its full torque and speed and is working like it was previously.
What's going on?
Thanks!
What's going on?
Thanks!
