neeleman
- Jan 2, 2010
Has anyone already noticed problems with the depth setting?
On the TS 55 R the depth setting can be adjusted with the black screw depending on the blade diameter/radius.
I assume Festool noted that when blades are sharpened they normally become smaller.
But with one of my oldest blades (still Festo) the depth setting cannot be adjusted enough to get a correct scale.
The blade is sharpened probably 3-4 times during the 15 years I use it.
And the diameter is reduced to 155 mm instead of 160 mm. That's only 2½ mm per side.
But hey don't we all want to work with sharp blades and the Festool blades are expensive enough to sharpen them several times.
It's still cheaper then buying new ones.
Solution: I replaced the standard plastic screw and spring with a M5 Allen bolt and now I can screw it down enough for adjusting the blade diameter.
I still find it strange that Festool has not thought of that.
I tried removing the whole green depth setting block from behind because I think it can be adjusted but did not go so far to dismantle the whole saw.
Maybe somebody from Festool can reply to that solution.
