mcmillansprings
- Feb 17, 2007
I have had a TS55 for a few years and not used it a lot. Until I started my Kitchen remodel and It has been great. The saw is in like new condition and has the blade it was purchased with which is clean and sharp. I was cutting down the width of a door a 1/4". The door is a 1-3/8" thick interior hollow core with a pine frame. I hooked the saw up to me CT22 vac and had it plugged into a 20amp outlet. The saw had a heck of a time cutting the door. The saw would stall and I would have to pull it back so it would come up to speed I finally had to raise the blade and make 3 passes to trim the door. If I would have use my Hilti saw I would have been able to do it in one pass no problem. I thought the Ts55 could handle this with no problem. Is this a common problem with this saw or was I doing something wrong.
