TS as a jamb saw?
So, I searched couldnt find much.
Can the TS 55 or 75 for that matter, be used like a jamb saw?
Any one try this?  Seems by looking at the saw it should work.
I dont see too many problems with this,  dont say nails because I dont care about hitting nails.  I use the crap out of that saw and have an extra muck blade or two!
Any thoughts apprciated.
The TS saws can sort of be used as a jamb saw, depending on exactly what you want to do.
Unlike a Crain 555, which is designed for flooring jobs, you can't easily get a flush-to-floor cut with a TS. I just got in from using my TS 55. Since it was laying on top of the MFT, I measured and it was about 10 mm from flush.
Jamb Saw blades  have offset mounting to allow for flush cuts.
Did I understand what you wanted to do correctly?
For jambs, I use the Multimaster and am very happy with the results.
I did use the TS55 to undercut the toe-kick on a  set of built-in cabinets.  It worked OK, but not as well as a true jamb saw.  The biggest downside is adjustment.  I had to plane down a strip to get the cut the desired height, where a jamb saw allows you to adjust the height.
I have a MM, Bosch flush cut saw and I used to own a Crain jamb saw.
I thought the 55 with a spacer under it would get me they same thing as a Crain saw.
Plus I was trying to eliminate most of the mess.
It does work, and does eliminate most of the mess.
I used a  strip of MDF planed down to the desired thickness as a spacer.  It would be a pain if you had several different thickness to deal with, you would have to make a spacer for each one.
I also had a Crain, until someone broke into my truck box.  I didn't really use it enough to buy a replacement.
Second that on the Crain however, mine did not get stolen, just collected a lot of dust!
I Just have 2 door jambs to deal with and a cased opening to another room so it wont be too bad.
Thanks for the user feedback.
Well, it worked just as well as my old Crain saw did, maybe better because of the lack of a dusty mess!!
That's good.
When I use my supercut (larger version of multimaster) I often hold a vacuum hose up near the blade and capture a lot of the dust. This is pretty easy because the tool handles well with one hand.
Erik
Hi guys
I would not use my TS as a jamb-saw ever.  I have 2 Crain 825's ( I am a tile setter) there are too many 16 penny nails hiding right there waiting to THRASH :'( :'( :'( a $55.00 blade.  If you are in a pinch use a long flexible sawzall blade and a block the proper height to undercut your jambs.
(edited portion) I just noticed your statement about nails so cut away.  but try the sawzall trick and see if it works for you.
