ts55 - How Many Blades
DanielOB
How many (Festool 48 tooth, 2.2 mm kerf) blades it could take to make one average kitchen cabinet (kitchen is c. 20 sq.m) and counter top (50% plywood 3/4" and 50% solid wood Oak/Maple 3/4").
Any info will be useful
Hey Daniel,
Good question. It all depends on what material you are cutting. I do a lot of cabinets, as many other Foggers do, and I have 2 48 tooth ( 495377), 3 28 tooth (496304) and 1 Solid surface/Laminate 48 tooth ( 496309). The reason I have so many is that when some go out for sharpening I'm not sitting idle. I make it a practice to have 2 of every blade for all of my saws.
JC
A good rule of thumb is to have 3 of every commonly used blade.  One on the tool.  One in reserve in case the one in the tool goes dull or is damaged and one at or ready to go to the sharpener.
One blade.
So if you are doing them non stop then you have a few.
If you are doing one, then just go like hounds of hell are after you.
Daniel,
I am still using the blade that came with my DeWalt track saw.  So far, it has cut up around half a dozen sheets of waferboard, 3 sheets of 3/4 CDX, and half a dozen 1x12s.  It has also cut down at least 3 doors.  It is starting to get a little dull and it's replacement, an Oshlun, is here waiting for me to decide to put it on.
A blade will easily do one cabinet.  It should do a wall of cabinets before requiring sharpening or replacement.
Jim
The combo blade that comes with the saw should be good enough. The Festool blades are like the energiser bunny, they keep going and going
In January 2006 the TS55 had not been available in the USA very long when I bought that as my first Festool. However, the 48 tooth fine-tooth blade cat. 495 377 had also been used with the previous plunge saw.
Until then my policy had always been to purchase at least 3 identical blades for circular saws: one to use; one being sharpened; one in reserve. At that time I only had two weeks of vacation left to build a very complex prototype of a media console involving many miters and bevels. I could not waste a minute being without a sharp blade. So I bought the needed two extra 48 tooth blades.
Months later after I had used the same blade on nearly 200 sheets of 19mm plywood I realized I was still using the original blade. I had cleaned it a few times but continued using it because the cuts were so good. Only then did I send the original blade to be sharpened. My grinder remarked that I was sending in a new blade.
Well, since then I have purchased 11 more TS55 and 2 TS55R. Long ago I stopped buying 2 spare blades for each of them and I also stopped keeping records of how many sheets a particular blade broke-down between grindings. At this time I own 26 48 tooth blades. One of my TS55 is kept with the Solid Surface/Laminate blade and another TS55 with the Aluminum/Plastic blade because I find each of those special blades make even better quality cuts on certain kinds of sheet material.
My experience using Festool blades has been very positive. A few of my older blades have been sharpened more than 6 times, so I have yet to discard a Festool circular blade. When asked my advice to those earning a living with a TS55R is to buy the two extra blades because missing a day will cost far more than the blades. I suspect when blades know I have spares then deliberately last longer.
I bought my saw  years ago. way back when I joined the fog. (august 2010  OMG  [eek] [eek] 5 years)
I still have the first blade . it has cut loads up , I was doing a job that needed to cut acoustic dry wall , cut edge left exposed on the ceiling
that blade needs sharpening.
I bought another 48 tooth and a ripping blade.
I use the ripping blade most of the time. and It needs cleaning and maybe sharpening , its on the saw 18months. I cut up 40 sheets of phenolic faced ply with it last week and didn't chip it (probably the reason It needs sharpening)
I use the 48tooth for laminates and worktops. its perfect
a blade should last a long time on a saw
Thanks guys
I have now 3 Festool 48t blades for my new TSC55 (battery), and I will order two more.
It will be used for final cuts only, and for all of other cuts I will use my Bosch Circular-Saw, modified to get onto Festool rails. I think that way I will have Festool blades for life.
I am moving to part of Canada where a blade shipping cost and time are considerable high (not acceptable).
Thanks again
