Some members may remember this thread, which discussed a revised baseplate for the TS55 saw.
I was browsing the
Festool USA FAQs, and found one
article which gave quite a lot of interesting information about the new baseplate:
Question :
Is there a new improved base plate for for TS 55 EQ?
Answer :
In the next few months any new production of the TS 55 saw will have a slightly different version of the base plate installed. This new base plate will have replaceable inserts at the slide surfaces, so that if these areas wear, the slide surfaces can be renewed without changing out the entire base plate. Wear is not an issue under normal use.
The improvement was made for specific customers that are cutting hundreds of feet of solid surface and granite composite countertop material on a weekly basis. The abrasive dust created by solid surface materials wears out the base plate along the slide surfaces prematurely.
This has never been an issue when the saw is being used to cut wood. Again, let me emphasize that premature base plate wear is not an issue under normal, daily use.
If the base plate of the current model saw wears out prematurely and the saw is sent in, it will be replaced with the new base plate at no extra charge under warranty. Please consult our service department prior to sending your saw in, as Festool will not automatically replace the current base plate with the new version of the base plate at no charge unless it does wear out prematurely.
There has been lot of hubbub over the new version of the base plate. Again, it is only when the saw is being used for cutting solid surface materials under extreme conditions that this has ever been an issue.
Premature wear resulted from shops using the saw to cut hundreds of feet of solid surface material every week. There is no benefit to the new base plate other than this simple modification. On the newly designed base plate, if the small black plastic parts wear out, you simply exchange them rather than the entire base plate.
I trust this clears this matter up. This change is for the TS55 only. Nothing has changed with the base plate of the TS75. The saw with the new base plate will begin shipping soon.
Forrest
