mino
TSC 55 > TS55 >> Makita >> Cheapo tracks saws.
The SP600J has no right-side anti-splinter and the sliding on the rails is sub-optimal /does not hold reliably and needs replacing when worn/.
What you want to stick to though are the Festool FS/2 rails - if you need precision that is.
The Makita and Triton ones are cheaper because they are made less precise (i.e. less straight cuts) and have way worse anti-slip pads so require use of clamps much more often. Just not worth it and you can always sell the saw for an upgrade much easier than the rails ..
