Just bought this off a mate, he was not aware of any problem with it and I may be being picky. Powered it up on speed 1 and it makes a bit of a rattle on start up then oscillates with the same noise and slight vibration. As I ramp up the speed towards max it becomes less noticeable most likely because the vibration is a much higher frequency. I understand that without hearing this directly it's very hard to comment but should I be expecting a seamless and smooth start up and running with no rattle? The blade has no lateral movement but does have a small for and aft movement which I would expect. The unit is in mint condition, has not been dropped, has had little use and is less than a year old.
Should I take it to my local dealer and do they honour warranty if I didn't buy it? (I have bought a lot from them!!)
Cheers
Zeb
Cheers
Zeb
