I have a Panther blade and have yet to use it. Instead, most of the time, I use the 28 tooth universal blade on my TS 55. Although the specifications published by FestoolUSA indicate its kerf width to be the same as that of the fine 48 tooth ATB blade, I found myself cutting off more of the splinter guard strip on my guard rails.
Since the Panther blade is not intended to produce a "glue-line" ripped edge, you could make your own guide rail from a piece of 1/4" plywood to which is attached a hardwood rib for the base of your TS saw to ride in. The first rip cut of your homemade guide rail will trim its edge. Long ago a made a similar rail which I used with my Shopsmith to create a straightline rip on one edge of rough sawn lumber. The only differences from the homemade Festool guide rail were use of a hardwood strip sized to fit the mitre gauge slot of the tablesaw (3/8" x 3/4") and some sandpaper glued to the top surface to help grip the board being straight-line ripped, and a simple stop at the back end to ensure the board doesn't slip lengthwise relative to this straight-lining jig. Worked like a charm, and I still have it. Wax the wooden guide strip to facilitate movement of the ripping jig relative to the saw. I might try this one myself.
Here are two other possibilities. I haven't checked this one out - is it possible to engage the groove in the base of the saw with the open top raised rib at the back edge of the guide rail? The base of the saw extending outward from the back rib of the guide rail would have to be shimmed to avoid cutting a beveled edge on the workpiece, but this could be accomplished with a piece of ~1/4" HDPE (UHMW plastic) or similar shim material. Or simply clamp your guide rail and run the saw with its base resting completely on the workpiece to be ripped and abutted against the back edge of the guide rail. Both of these assume you are not seeking the same degree of precision in your Panther rip cut as you expect when using the guide rails in the normal manner with a precision (fine cut) blade.
Dave R.
