I have a TS75 with the 1900mm (75") rail and have been using it to cut a 5' x 5' x .7" sheet of Baltic birch into 5' long by 5" wide strips.  I noticed that, after completing my cuts, if I pushed the two freshly cut pieces up against the remaining plywood the ends would meet up nicely but there was a noticeable gap along the center of the cut. After cutting a couple of strips, I measured the width of the outer ends and the width of the center of a strip with calipers and found the center width to be 0.01" less than the width at each end.
Procedure:
- Lay sheet on top of two pieces of 1" rigid foam with about a 1/2" gap between them for blade to run through.
-Checked the factory edge of the sheet by eye for straightness (not the best way but it looked straight and when I sight down my problem strips the 0.01" "bow" was very noticeable in comparison).
-Set a combo square to 5" + blade kerf and set the edge of the splinter guard (the splinter guard had previously been cut to match the saw for full length) on the rail up against the end of the combo square at each end of the panel. Adjust at each end back and forth until splinter guard is snug against end of combo square at each end.
-The rail extended past the sheet about 9" on the starting end of the cut and 6" on the far end. I supported the ends of the overhanging rail with some scraps the same thickness of the panel. My cams are set so the saw doesn't wiggle on the rail but still slides freely.
-I put the kick stop in right at the end of the guide rail and but the saw up against it. This puts the center of the blade pretty well right over the edge of the plywood so I begin the cut by plunging in then advancing at moderate speed listening for any sound of the saw bogging down and stopping when the blade exits the far edge of the plywood.
Has anyone else had this issue and if so have they found a fix? I have read that the saw comes set with a slight toe in attitude, could this be causing my issue due to beginning my cut on a plunge or is 0.01" an acceptable deviation over 5'? I would like to use the saw to build cabinet cases so I am trying to work out the kinks in advance. Any replies/criticism are appreciated.
			Procedure:
