I was cross-cutting a long 2X12 Southern Yellow Pine board (I'm making my first workbench) and my TS55 got stuck. I started the cut in the middle of the board, and when I got towards the end (edge) of the board, the saw immediately jammed. It was stuck so hard I could not budge the saw.
I slowly worked it out as carefully as I could (took about 15 minutes). I didn't "muscle" with all my force, but I did have to pull on it quite a bit. I basically rotated the saw around the edge of the 2X12 and finally pulled it out (with quite a bit of force).
Is there anyway I could have damaged the saw? maybe bent the arbor or something? This is the first time I've really started using the saw and I hope I didn't break anything.
Thanks,
Greg
Thanks,
Greg
