Tinker said:semenza said:Hi,
Tinker, when you say the "standard" blade - do you mean the one (Fine) that comes withthe saw or the actual Standard (487377) blade?
I have the older ATF 55. My blade is the 28 tooth that came with that saw.
Tinker
And I've got an ATF 55, and mine came with the 48-tooth. So in my case the 48-tooth was standard.
Festool currently lists a 12-tooth "Standard" (487377) and a 28-tooth "Universal" (490516), but continues to ship TS 55s with the 48-tooth "Fine" blade (491952). Oh, and there are two different "Special" blades. Only the "Panther" blade has a clearly unique name.
The most reliable way of telling others what blade you're using is the part number. "Standard" and "came with my saw" just don't work.
Ned
