TS55EQ blade for 1-1/8" OSB
rossn100
I have a bunch of 1-1/8" OSB that will need to get cut for subfloor installation. I have a 2006 TS55EQ with the 48 tooth and 12 tooth blade. Should either of these blades work OK for the material and thickness (I usually feel the TS55 is a bit underpowered). If not, do I need to get the 28 tooth blade? I probably have about 25 cuts to make.
Thanks!
I’ve often used the hkc55 to cut double layers of 5/8 or 7/16 osb. Zero issues- different saw I realize but osb cuts like butter in my experience. That subfloor is heavy af- hopefully not too many sheets to do lol
