For ripping timber, you need the panther blade. With that blade you can run it at full speed if you want, or slow it down a bit if you prefer.
The 48-tooth blade is not for ripping solid timber - you can try it if you want, but the timber will burn, and your blade will be blunt fairly quickly.
