bnaboatbuilder said:
That 1/10th of a millimeter difference (per one side of the blade) at the rail splinter guard would be 1/254 of an inch or 0.005". That seems incredibly small for the world of track saws as to need to worry about it. These aren't table saws when it comes to that level of accuracy.
Okay, this is where our experiences differ. I have owned and used state of the art table saws intended for making precision parts from plywood since 1946. In 1959 I added power feeds which were believed to increase accuracy of the table sawing as well as improve safety. The day I bought my first TS55 and several guide rails in 2006 I had intended to purchase a large sliding table saw. I had been using one of those, made in Germany, belonging to a friend.
I had always considered myself an expert getting the most accuracy from table saws. In 2006 what caused me to buy the TS55 and system was that I got the same quality of cut. With care and proper technique I had absolutely no problem making parts as accurately using the guide rails. An additional advantage was that the plywood was stationary on the sacrificial surface and the guide rail protected it from scuffing and scratches caused by the saw. That is always a concern when moving the plywood across the table of a saw; even with a slider table, some of the work is moved across the stationary table.
This is why beam saws have become popular in production. Like using a guide rail the saw moves through the work. Between cuts the air bearings lift the plywood so it is not scratched and scuffed. The pressure beams virtually eliminate tear-out. My CNC beam saw repeats day after day to 0.02mm and is absolutely square in all directions. Plywood with expand and shrink far more than that unless assembled immediately.
But with decent technique and accurate squares, the odd angle parts I make using TS55 and guide rails are as accurate as needed. A beam saw can only make right angle cuts and no bevels, unlike a TS55 and a guide rail. The slider saw can make those same bevels and odd angle miters, but not was rapidly as with guide rails. Also, since the wood needs to be moved twice for each cut on a table or slider saw, the physical effort is doubled.
But then your mileage might vary.
