Cutting speed recommendations that Festool provides are about the type of material. Hardwood, for example, is 3-6. How about material thickness? Would you use higher or lower setting when cutting 60 mm hard maple, for example? I realize there is feed rate to take into account with cut quality being the ultimate criteria, but I like splitting hair and just curious what are the preferences. My experimentation results are inconclusive. Not the least of concerns is which speed is easier on the motor when dealing with thick dense materials.
Thank you.
Thank you.
