TS75 Leaking
presidentsdad
Hey all,
I have a new TS75 that seems to be leaking some grease.  I wiped it off and it hasn't returned, but just wondered if I need to worry about it. I've used it probably three or four times.
I wouldnt sweat it. I have a TS 75 and it did the same thing and its running great
Normal out of the box.  Just check down the road to see that it hasn't reoccurred.
Update, I did have more grease leaking out, so I sent it in for service.  Festool fixed it in 3 days and had it back in my hands.  So far so good.
It is common to leak a bit in some cases.
After recent service it leaks a bit excess when it gets hot.It will stop after a week or so,
If ball bearing in motor housing has wear out,it lets the grease flow and need to be changed,
If grease is old and lost its properties.
One or more of the above reasons.
