TSO announces new "Chamfer Dog" 20mm bench dog family
TSO_Products
Retailer
[size=18pt]Bench dogs are a great, economical way to position workpieces on your 20mm hole patterned worktop for accurate and repeatable results. While traditional bench dogs rely on an enlarged collar resting above the work surface and are suitable for a wide variety of applications, our new Chamfer Dogs have a few new tricks up their sleeve:
* Thanks to their precision machined chamfer detail, these dogs self-square and self-center within their holes. Even if the dog hole is slightly oversized or worn through extended use, Chamfer Dogs will rest in the same center position, every time. This makes Chamfer Dogs the best choice when maximum layout accuracy is required.
* With no above-the-worktop collar, Chamfer Dogs present a perfectly uniform vertical surface perpendicular to your worktop. This makes them ideal for positioning workpieces with rounded edge profiles, or when you need to align stacks of sheet goods for a single cut.
* Without a large diameter collar, Chamfer Dogs are more compact and easier to store, yet offer the same capability.
Shop TSO Chamfer Dogs
Thanks for your support!
- Hans & the TSO Team
None of my Veritas bench dogs have collars on then and why should I want that precision and accuracy, for a CNC machine would be my guess certainly not for bench hand work.
There is a market for "use dogs for CNC accuracy" growing up from the grass fields. And these dogs are squarely after that market.
One may consider it futile, but they do provide better accuracy (at reasonable speed) than most other flexible options out there as of now. The Market has spoken.
After reading the OP again the first paragraph puzzles me as to the primary use of the new bench dogs.
