TSO Easter Egg Savings: Up to 10% off plus free shipping in contiguous USA
TSO_Products
Retailer
[size=18pt]We're adding some special savings for the Easter Weekend: 10% off TSO and MICROJIG products, 5% off UJK products, and FREE SHIPPING in the lower 48 contiguous USA on orders over $49. No coupon codes necessary as discounts are automatically applied. This sale ends April 9 at 11:59pm ET and is limited to stock on hand.
Visit TSO Products
Here's a few of our most popular products:
JUST RELEASED! MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check our our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
GRE-13 Guide Rail Extension
Provide more support at both ends of your plunge cuts with this 13.7-inch (346 mm) guide rail extension, which conveniently fits in a Systainer. Connectors included!
Are the MFT aligned support plates anodized?
The appear not to be anodized on the TSO site.
which anodizing finish would interest you?
- Cosmetic appearance?
- Functional reason?
Hans
info@TSOPRODUCTS.COM
Hans
Are they anodized? That was the question I was trying to ask.
[member=67413]box185[/member]  - at present, as you can see on our website, the MFT Aligned components are shipped "as machined" with  no anodizing. We wrestrled with that decision and decided in favor of lower cost for the customer - pending customer response - like yours.
We coould not see a compelling reason / benefit for the added cost since the parts don't come in regular contact with wood or the user.
Help us with your feeback, please.
thank you
Hans
info@tsoproducts.com
