TSO Parallel Guides - $275
KHNewman
Gen 1 TSO Parallel Guides
Excellent Condition - Lightly Used - Purchased New in August 2025 for over $430
Drop-on & Lock-in Slide options
Works with Festool and Festool Compatible Track Designs
Set Includes:
  • Two TPG Adapters (Drop-On) for TPG Parallel Guide System 61-388
  • TPG Parallel Guide System - TPG-30: Includes Two 30" T-tracks - 61-628
  • Two Track Guide Flip Stops
  • Repeatable Precision: Single-piece aluminum Parallel Guide Tracks with dual-dimension scales and Flip Stop Pros deliver predictable accuracy with every cut.
  • Faster Setup: Universal Parallel Guides and Drop-on Connectors install and remove in seconds, so you spend more time cutting for Festool Compatible Tracks.
  • Unmatched Capacity: Make parallel, repeatable rips up to 30" wide.
  • Universal Compatibility: Works with Festool or Festool Compatible Tracks
I will include the wall storage rack shown in picture. (Please note the wall mounting rack is a little snug and I had to grind it to get the guides to fit but it is included at no extra charge)
