TSO's Big Dog Pack - Bundle & Save $65 - Featuring our new Chamfer Dogs
TSO_Products
Retailer
[size=18pt]Save 13% off when you purchase our best-selling bench dog and work stop products in our new TSO Dog Pack Bundle! The kit includes a fully-loaded systainer chock-full of 16 just-released Chamfer Dogs, a pair of our TDS-13 Dog Stops, a TSO blue Systainer3 M 112 enclosure, and a custom CNC-cut Kaizen foam insert to keep it all together.
Check Out the Dog Pack
This bundle includes:
TDS-13 Low Profile, Super Long Dog Stop
The most versatile accessory for your 20mm worktop! Perfect for workpiece locating and general workholding, a robust work stop (especially convenient when using the Domino), and can even be oriented diagonally across your table to act as an 45 degree angle fence for miter cuts with the track saw.
20mm Chamfer Bench Dogs
Thanks to their precision machined chamfer detail, these dogs self-square and self-center within their holes. Even if the dog hole is slightly oversized or worn through extended use, Chamfer Dogs will rest in the same center position, every time. This makes Chamfer Dogs the best choice when maximum layout accuracy is required.
Custom Kaizen Foam Insert
Kaizen foam not only protects your precision tools but can also be easily further customized with careful use of a utility blade or Kaizen foam hot knife.
TSO Blue Systainer3
Systainers: organization made easy. The Festool/Tanos Systainer3 platform offer a rugged, flexible, and convenient means of storing and transporting your TSO precision tools.
