I recently purchased the UJK hole reamer from Axminster to deal with some holes that were too tight on my Baltic Birch MTF made with the Parf Guide. Overall the reamer is a pretty food product, with a few caveats.
First, they probably should have made it out of tool steel instead of stainless. It would hold an edge better long term. That said, considering it should only need to be used on occasion the reamer will probably hold an edge just fine. I just get nervous when I see cutters made out of stainless steel.
The reamer works fine but you have to be careful not to let it chatter. As soon as that happens the holes will be a few thou (yes, Imperial!) too large and the dogs will be a loose fit. Fortunately I figured that out after reaming only 3 or 4 holes. To be honest, I had better success dealing with the tight fitting holes by running a Parf tall dog up and down through the hole a few times to burnish the inside smooth. A clamping tool like Peter shows how to make is helpful here.
