Paul Wells
- Feb 25, 2021
Hi all,
I've just purchased the mk1 guide system, and noticed that the new rules, have both 3mm and 6mm holes for the drill guides, I assume, this so only need to produce one rule for both kits, also the guide pins seem to fe the same as used in the mk11, as is the 20mm jig,
My question is, as I've not had the chance to use this yet due to work commitments,and being away from the set, does anyone know if you can use these new rules to drill offset holes, using the 3mm hole positions. I havnt got any pictures of the new rules, but they have the 6mm holes and also a set of 3mm holes.
Thanks in advance.
Thanks in advance.
