I have just changed the blade on my TS75 - the original blade that has been fitted for longer than I care to think.
I needed to trim some 75mm butcher block worktop and, whilst the old blade was cutting ok, I thought I would get a better finish with fitting the spare new blade I have had sitting there for ever. Wow! What a difference - new blade gave a much better cut.
Not surprising really as the old one has done a lot of work, mostly on man-made boards; but the moral of the story is that I have clearly not been changing blades often enough, even though they do the job and look in good condition - next suspect is the Kapex.
I would be interested to know what others do about sharpening as, whilst I have numerous blades for different machines, I have never actually had any sharpened:
- do you sharpen or just replace?
- what are the economics?
- how do resharpened blades compare with new ones?
- where do you get your Festool blades resharpened (why do Festool not offer this service?)
- how many resharpenings do you get per saw blade?
I think there is no answer to the question of how to tell when a blade needs replacing - but any suggestions?
Cheers
Cheers
