Unusual use for domino
Mavrik
I made a hifi amplifier.
I needed to make vent holes in the baltic birch top.
Suddenly realized that the domino would be perfect.
Worked beautifully.
That is an awesome idea!  I'll have to remember this.
Maybe this would be a good thread to post other Domino uses.  I've used it to make mortises for the back slats of a porch swing.  A 3/8" beading bit seemed to work perfectly to get the
I too found an unconventional use for a domino. I found it made a perfect size hole for my Bessy quick clamps.
I used my domino to repair this broken portion to hold a table leg attached. I glued the broken pieces back in. Then mortised deep enough to get past both holes. Then I drilled the holes through the inserted domino. It's holding quite strong still
