HI
I'm having serious trouble with my new domino.
The material thickness scale is way out! I have tried to adjust / calibrate it with no avail.
When I use the pre determined thickness stops, I read the scale and it is off by 1-2mm? ???
I have since calibrated it... by:
1.) Using the pre determined thickness stop
2.) Then adjusting the scale to suit half of this thickness.
All is well and dandy, but when I read the next thickness stop, its slightly off again. The next stop further its even more off. As I use the pre determined thickness stops, the higher up I go, the more out the scale is.
It works the other way too. If I calibrate the thickness scale with the pre determined thickness stops; its not too bad for the first to stops, however as I move down the thickness stop scale, the error is magnified. Leaving me out 1-2mm by the time I am on the lowest stop.
Please help! I love this tool but have never had accurate results with it. I think it may be a dodgy plastic thickness guide.
Any help appreciated!
