Using a domino for mitres
splinter
Picking up on an old thread, this may help some of you avoid hours of anxiety and rage as you wrestle carcasses together as the glue is rapidly drying.
My preferred corner joint for sheet goods like Birch ply, is a mitre.
But they are a nightmare to assemble and glue accurately and using dominoes (or biscuits) in the conventional way, requires six hands and large numbers of sash cramps.
By placing the dominoes vertically as suggested by an earlier contributor, the assembly becomes straightforward and fast.
As long as the mitres are accurate it is simply a matter of dropping the top panel onto the dominos which act as locating pins.
The critical requirement is that sheet material must be exactly the same thickness as the slightest variation will result in a misaligned joint so try not to mix different sheets.
I thought of this method a while ago but dismissed it unworkable but reading the earlier thread I thought I would give it a try and am glad I did.
The thread was called 'Joining Mitred Edges with Dominoes' and the contributor was Square.
Dated July 10 2008.
Hi Jakilski,
Origin: Late Middle English from Old French via Latin from Greek mitra, 'belt or turban'.
The English usage is clearly superior.... obviously!
jakiiski said:
Are they actually pronounced the same way or is there a difference even in that?
Yes pronounced the same, unlike Theatre and the american spelling of Theater! It's what makes language so interesting.
[off topic]
Splinter... how can the english usage be superior when we've taken most of our language from other languages, it really is the original Esperanto!
My favourite word, etymology speaking, is LUXURY. Taken from the Latin LUX meaning light and apparently popularised when candles were taxed.
If you were wealthy you lived a life of light from many candles thus luxury!  How accurate the root story of this is I don't know, but I like it ;D
After all there was once a tax on windows in the UK which is why some really old buildings have obvious areas of bricked up windows!
Back on topic [big grin]
This is where the Domino beats a biscuit joiner , greater choice of cutting depth and widths, plus not stuck with just 3 sizes "tenon".
Rob.
