Question for the cabinet guys. I'm about to start a cabinet refacing project in bamboo. Doors I will build from plyboo and edge with 1/8 strips. At present the cabinet have a kinda glossy thermform smooth finish. Should i Veneer over top since the surface is smooth or remove it completely. The other problem I have is the old edge tape. Should i remove and clean off the glue. There seems to be so many edge tapes out there but which is best for a professional finish.
I have access to fleece back so can use contact adhesive to stick. There is also peel and stick which uses a 3m product for glue or regular iron on. What do most of you cabinet guys use?
thx
Lambeater
thx
Lambeater
