When I bought my first TS55 it came with one 1400mm guide rail. In the same transaction I bought a coupling set, 2 more 1400 rails and a set eack of the quick and short screw clamps. Right away I got in the habit of using one or the other kind of clamps. I do not remember ever not using clamps with the guide-rails.
BTW, I typically use a sacrificial sheet as the surface on which I plunge saw, mostly to reduce underside chipping. All those sacrificial sheets have 20mm holes drilled using my OF2200 for dogs or clamps. They are not spaced as regularly as a genuine MFT, but I find a 20mm hole is like all 20mm holes.
