Hi. I've got about 600 linear feet of Limestone tile to cut with a tile saw. After cutting the edges have to be eased (a slight bevel) a little to match the top of the Limestone.
I tried using a Makita 4-1/2" grinder with dry diamond pads (400, 600, and 800). The good news is that the edge polished nicely. The bad news is that the edge wasn't even - the grinder is difficult to control for a small, even bevel.
So I tried my RO150 with 500 grit Platin. It worked pretty well and quickly gave a nice, even bevel. However, I might need to go to a higher grit for a nice surface.
My questions...
Is this even reasonable? Will I be going through a lot of sandpaper quickly?
Has anyone tried this on Limestone tile?
Will Titan 2 work better?
Thanks,
Dan.
My questions...
Thanks,
Dan.
