using the mfk 700 for counter top laminate
honeydoman
Honorary Member
Well just finished this laminate job.  The mfk 700 worked very well and easy to use.
After removing the old tops, I cut up 3/4" cabinet ply to size using both of my mft 3 tables. to suppport the ply while I ripped it to size using my ts55 and rails (I forget my 106" rail at home so I just used the smaller one and moved it.  I also used the domonio to connect the 2 pieces together and it worked great.
then I applied the side strips and used the router to trim the top and bottom edge of those pieces.  using the laminate bit.
Then I laminated the top pieces and ran the mfk700 around the edges and it worked very well and easy.  I did not attach the vac hose due to my first time using the bit I did not want the hose to catch on anything and mess it up.  If I had my overhead hose holder then that would be different.
and it really made a big mess with all the laminate trim off all over the place!  but I had tarps down and it was a rental house and I had my vac to clean it up.  That was safer and easier then worring about the hose catching and buying more laminate.
I could not take any pictures of me actually using it to laminate since I was working alone that day.
so overall, I was very pleased with the results and would recommend using this tool for this type of job...
