Hey Magellan it's a great system...especially handy for sanding and for use with the Domino. I've seen a couple of vacuum heads on the recon site but I can't remember ever seeing a vacuum pump.
As rst so elegantly stated, "if it sucks enough you can use it." Can't agree more. [big grin]
There are design/material differences in quick disconnects used for pressure applications versus vacuum applications. The differences are subtle and important if you're putting someone on the moon, however if you're just holding lumber, it really doesn't matter. I used the standard Festool/Festo quick disconnects but that was just my choice. In case you're nervous about switching quick disconnects, just remember that you can utilize the vacuum chamber in the bottom of the vacuum head base to increase the leak-down time if something does go awry.
