Vac sys vacuum pump doesn't run.
Rob Grierson
I have had my vac sys since they came out last year and have used it a lot but not daily. One day it was working then the next nothing. The motor just hums. It doesn't spin up at all. Anyone else have a problem with their unit?
Before returning the pump, maybe try to see if you can turn the motor just a little bit (can you touch the cooling fan with something?). It's a fluke, but a motor can come to a stop directly between poles and not be able to turn until it moves just a little off center.
Otherwise, yes, the capacitor is most suspect.
