Vacuum question.
Lbob131
I currently have  the CTL 26 E AC  for  some  time  now.
I might  try  the machine  with  cement  board  dust  when  routing.
Can I  retain  the use  of  the  long  life  filter  bag  (the  one  with the plastic strip sealing  the end)  in combination  with  the CT pre-separator CT-VA-20?
Or  will  the fine  dust  not  collected  in  the  pre  collector  still  block  the  bag  leaving  me  with no suction power?
And  a question to those  of you  using  the plastic  liner, do you  empty  it  and  re- use  or  just  chuck  the lot in a  skip?
Hi, I don't see the advantage of the ct va 20 with the ac machines with cement or drywall dust,we use the liners,we for a while were worried about supply,but it was and still is messy same with ctva 20 liners or tubs, good luck guy
