Vecturo OSC 18Li
Bosch make a couple of carbide teeth blades for sheet metal and steel bar cutting etc.
- OSL114C or OSL114MF
- OSL034C
Maybe those do what you need. Might be more readily available than Fein...
The Vecturo has a StarlockMax“ Tool holder.
Starlock is a Standard developed jointly by Fein & Bosch.
There are three Versions:
- Starlock
- Starlock Plus
- Starlock Max
The Plus and Max Versions are for Blades that require more power from the tool.
So only specific machines can drive these.
But they are downwards compatible.
So, when your machine is certified for Starlock Max (Vecturo, Fein SuperCut, Bosch GOP55..) it can also use Starlock Plus and Starlock Blades.
When your machine is certified for Starlock Plus (Fein Multimaster, Bosch GOP18V...) it can also use Starlock blades, BUT NOT STARLOCKMAX.
hope this helps...
