Hi Will,
It's hard to beat the router. If we're talking about small jobs, then I can reed or bead without test cuts, unlike using a router. There's little set-up time with the combo plane (assuming you use it often) as compared to installing a router bit, setting the depth of cut, fence, featherboard, etc.
