- Jan 22, 2007
I suspect most of you know how to do this already. Hopefully you're using the FastFix blade change system already to swap blades depending on your application. I also have some video of the Panther blade which shows that it's more than twice as fast as the stock blade at rip cuts. FastFix makes blade changes so easy that there's no reason not to be using the right blade for the job every time.
Changing the blade on the Festool TS plunge saw
Note: YouTube video quality is low directly after a video is uploaded. After 2-3 hours, the quality will improve and the HD quality will be made available.
