There are a lot of debates on this forum. “Which Domino is better DF-500 or DF-700?” DF-500 is sufficient for most woodworker’s needs. I do own both, but I mostly use DF-500 machine for cabinets, chairs and tables. I built these chairs as an example of sufficiency Domino DF-500 machine.
[attachimg=2]
[attachimg=3]
Slats and stretchers are custom made oversized “dominoes”. Board was cut in 10mm wide strips then rounded over. For slat’s mortises I used the widest domino width, for stretchers the narrowest.
[attachimg=4]
For assembly were used 12qty. 10x50 dominoes.
Legs are 36mm (1 ½”) planks. I cut ends of dominoes at 45 degree angle. This brings more glue surface, and more reliable joint.
[attachimg=5]
It’s very hard to find 5mm round over or 10mm bullnose router bits, so 3/16” round over router bit was used for making slats and stretchers.
[attachimg=6]
All sanding job was made with Rotex RO-90 and Granat abrasive pads. Oh, man, that’s something!
Finish is surfix oil.
[attachimg=7]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
