Packard
I just bought this watch, which claims to have a 10 year battery (Casio Module 3502):
I suspect that it is a standard battery teamed up with a low current draining display.
It is a large display and very readable as long as you are facing it directly. If the face is at an approximately 15 degrees angle it loses contrast and is difficult to read. At 20 degrees the face goes black.
The main advantage was that the 10 year battery teamed with the low drain display only cost $24.00– less than the cost to have a battery replaced at a mall kiosk.
The last time I had a battery changed (several years ago) it cost $40.00). Movado charged me $100.00 to replace the battery on my Museum watch.
All my recent watches have been solar powered, but I read recently that the solar rechargeable batteries have a life span of 10 years—so no chance to save money there.
This watch uses 4 Philips screws to hold the backing plate on. If it takes a fairly normal battery, I will replace it myself.
I will keep this watch. It has an illumination button, but it still requires near zero angle to view.
Advantages:
Big face (51MM)
Cheap
Displays time, date, day, year.
Has 5 separate alarms (which I will never use).
Has a light bar that cycles every 10 seconds, which might be useful for timing short durations. (The curved bar with 10 segments to the right of the time.)
But its primary advantage is that it is cheap.
Advantages:
Big face (51MM)
Cheap
